Half-duplex serial comms #6791
Posted at 2024-10-28 by @gfwilliams Hi, I'm afraid it's not something that I is exposed - but presumably you could just attach a signal diode (so only 0.3v drop) between the STM32 TX pin and the serial line, so it's only ever capable of pulling the signal down? You could take a look at https://www.espruino.com/STM32+Peripherals though as it may be you can set the STM32 up as normal and then just Posted at 2024-10-30 by user157904 Hi Gordon, Thanks for your response. I managed to activate half duplex mode by poking the correct register as you suggested and all seems to work as expected. Thanks! |
Posted at 2024-10-26 by user157904
Is there a way to enable half-duplex UART on Espruino Pico? I have a device that I communicate with using standard serial over one wire, however I am using an NPN and PNP transistor to toggle between rx/tx. I believe that STM32’s have half duplex UART capability but I’m not sure if/how this can be enabled in Espruino. It would be nice to connect the directly to the pico instead of needing additional transistors.
