IO-Port availibilty depends on boards, using "wrong ports" result in reset #7426
espruino-discuss3
ESP32
Posted at 2021-01-22 by @gfwilliams Great - thanks for the update on this - that's a bit tricky. But if you don't reference D16/D17 in your code you don't get any resets? Posted at 2021-01-22 by JumJum Reset only happens, if mode for port is set. |
Posted at 2021-01-21 by JumJum
Depending on boards we use some ports cause a shutdown after setting mode for pin, like D16.mode("output").
Testing was done to check speed of different solutions for LED-Matrix(32x64).
Started with a board from Watterott, everything worked fine.
Switching to another board reset with same configuration.
Problem could be drilled down to usage of IO16 and IO17.
D16.mode("output") and I've got a reset.
Most boards don't have pins for IO16 and IO17, so be careful, not to use them accidently
