Extending storage module size? #7488
Posted at 2021-10-18 by MisterG I surprised how this seems to have zero views in the forum list. Is it true that no one wants a bigger Storage area? :P Posted at 2021-10-19 by Robin Mon 2021.10.18
It is more likely that as the ESP32 is an unsupported board, most of the community members support this project with their purchase of an authentic Espruino board.
Posted at 2021-10-19 by MisterG
There are ESP32 / 8266 community members -- so I'm guessing that people just aren't interested in a Storage module with a larger capacity, which is perfectly OK. I just posted to see the interest and if anyone had discussed it. I'll have a look at the module at some point myself I guess. G Posted at 2021-10-19 by @fanoush
This is some forum issue, noticed this with another topics too. The number can take some time to update - even one day or more. As for the topic - I'm not using Espruino with ESP32 but looks like the size and address of storage is set here https://github.com/espruino/Espruino/blob/master/boards/ESP32.py#L60 Posted at 2021-11-19 by Ruprect99 I believe you can use the FS module to access some extra storage. Format the extra partition using http://www.espruino.com/Reference#l_E_flashFatFS Posted at 2024-08-01 by lenxu Hello everyone, I've also encountered this dilemma. But my solution is to use the additional partitioning method from http://www.espruino.com/Reference#l_E_flashFatFS. By accessing https://www.espruino.com/ESP32#flash-map-and-access and using fs.writeFileSync to resolve the issue, but the problem is that this method makes the storage unusable. I hope to be able to use the additional flash memory together with the storage. Posted at 2024-08-02 by lenxu Additionally, I've encountered an issue when using the fs module. Specifically, when I call the fs.appendFileSync(filename, data); method and I repeatedly execute this code block within a setInterval function, I'm experiencing issues with missing or inconsistent file writes. Could you please assist me in resolving this when you have the time? |
@lenxu sorry for the huge delay responding to this. FlashFS was added before the Storage module was really very well sorted, but now it is there doesn't seem much point in having it. Much better to have FAT filesystems available for connecting to SD cards and use Storage (which can memory-map the data so is really fast). So, I've just pushed some changes to Espruno that remove the FlashFS code and adjust the partition table to give you access to the full amount of Storage (896kB). On a 4MB chip you've got 2 sets of normal firmware (1.5MB) to allow DFU, a few other small bits, and then 896kB is what you have left. If you were targeting a chip with 16MB we could do a new build and partition table that exposed all of that extra memory I guess. |
Posted at 2021-10-13 by MisterG
Hi everyone. I've been reading the posts on GitHub and here in the forums about making the storage module space bigger. It seems that the limitation is that it is "memory mapped"? But what does that mean "memory mapped"? I couldn't find exactly what that meant?
My storage area shows about maybe 220K free? I find that small, considering I have 4-16MB of flash space typically.
Is it possible to expand? I saw someone else ask about this somewhere, but no one responded to them.
Thanks! :)
