M5Stack ESP32-S3 kits #7505
Posted at 2024-11-25 by @gfwilliams
Yes - there's a board file called Posted at 2024-11-25 by @joakim Thanks for the pointers! The CardPuter is in the mail, so I'll give it a go when it arrives. If something comes out of it, I'll update here. Posted at 2025-01-26 by @joakim I tried flashing the S3 firmware shared by rgomezwap to the Cardputer using I haven't succeeded in building The Cardputer is a lot of fun though! Looking forward to running Espruino on it, and at least getting the display and keyboard to work. The goal is a tiny Espruino terminal :) Posted at 2025-01-26 by @MaBecker it is now available via flash tool https://forum.espruino.com/conversations/401440/#comment17639339 Posted at 2025-01-26 by @joakim Ah, I didn't catch that. Thanks for the heads up! Unfortunately, it's the exact same result. Could be something with the Cardputer then. Web IDE prints ";32mI (169) esp_image: segment 1: paddr=000534b4 vaddr=3fc9f9" this time, I don't know if that's saying something useful. Edit: I also tried flashing after disconnecting the StampS3 from the Cardputer, that is, disconnecting all its peripherals. Still no response from board after a successful flash. Baud rate is set to 115200 in IDE. I'm able to flash other firmware for the Cardputer and it works just fine, so I'm not sure what the issue is. Any thoughts? |
Posted at 2024-11-22 by @joakim
How well does Espruino support M5Stack's ESP32-S3 devices like the fun little $30 CardPuter?
Processor
From ESP32-S3Fn8 (Datasheet):
Memory
Resources
Links
Edit:
Searching the forum, I found this discussion about a community fork of Espruino for S3, with an interesting exchange about the business side of Espruino, where I fully understand Gordon's position.
So the answer appears to be: it's not supported, and the S3 fork is still young but might work.
This quote gives me some hope though: "I really love the ESP32 chips - I think they're fantastic (especially the RISC-V ones), and I do want to find a way to support them properly."
