micro:bit v2 #7530
Posted at 2020-10-13 by @gfwilliams Already ahead of you. I'm just about to push it live with the 2v08 release. I'd done a port but was under NDA until the announcement. The nRF52833 looks like a great chip, but is also a pain. Nordic only support it in SDK17, which has another whole set of pointless file/function renamings which seem designed to make everyone's life difficult. So for now, to get something out quick, I'm just using the old SDK12 with a one-liner to allow the second GPIO port to be used. It means only 64k is used right now but that's more than enough for most stuff. Posted at 2020-10-13 by parasquid Amazing! :D Can't wait until November when a local distributor rolls it out :) Posted at 2020-10-13 by @fanoush Oh, nice, the first one was old tech even at release day but this one is actually quite usable :-)
Interesting, so it runs including bluetooth? With S132 3.0? maybe the extra ram is only about linker script? or possibly enabling it in bootloader if it needs changing some registers Posted at 2020-10-14 by @gfwilliams
Yes, it's all fine. I haven't found anything that's broken at all. Yes, just a new linker script would do it I reckon - but long term it would be good to move to a new SDK I guess. I was almost there but there were just a few too many unknowns to get it working ok. Posted at 2021-01-24 by tcpipchip Hi, did you do “make” to nrf52833 ? Posted at 2021-01-27 by @gfwilliams Yes, nRF52833 works, albeit with a few hacks. Until a tweak by @fanoush recently only 64k RAM was used.
I'm not sure I understand. BLE Signal direction finding only works when used with a high-end multi-aerial gateway. I'm not sure they even exist yet Posted at 2021-01-27 by tcpipchip Hi @gfwilliams Bluetooth 5.1 Direction Finding service. The service can be used for indoor positioning, Posted at 2021-01-27 by @gfwilliams
That's what I thought. Read into it a bit more - it's as I said above. There is no direction finding capability in the individual devices Posted at 2021-01-27 by tcpipchip Nice! OFF TOPIC: How is going the Boufallo RISC-V implementation ? Posted at 2021-01-27 by AkosLukacs
Saw a demo somewhere, so they must exist :) But yeah, won't work with two devices with simple PCB antenna. And possibly multiple receivers to achieve the advertised centimeter accuracy... Posted at 2021-01-27 by tcpipchip @AkosLukacs Posted at 2021-01-28 by @gfwilliams Yeah, as I understand it the direction finding involves:
However you need a special receiver for this. I feel like it was probably possible even before Bluetooth 5.1 if someone had a sufficiently advanced receiver.
It's not I'm afraid. I'm just spread too thin to actually start porting to new devices right now. |
Looks like they just announced it: https://microbit.org/new-microbit/
It uses the nRF52833 and can use S140
I wonder if current builds for nRF52840 would work (with some pin adjustments) ?
