32L496GDISCOVERY: does not start USB serial #7695
ponyatov
Other Boards
Not sure what to suggest here - I only actively work on the F1/F4 ports as those are in the boards I use. The 32L496 port was done by ST themselves Does the LED flash? Is there comms via USB? That would verify that Espruino is at least running. What if you power it from the other USB and then connect the USB for the MCU after it has booted? And just to check, how about rebooting with BOOT0 reset - that should put it into bootloader mode which will at least verify the USB connection works. |
problem: Espruino console does not start after firmware load via USB drive
only programmer appears in device list after full reconnect & reset:
