Trouble with I2C devices on 2v25 #7716
Replies: 7 comments 5 replies
What's the clock speed on the F405 board? One thing that did change I recall is the I2C timeout got lowered - I forget exactly but from something like 0.5s to 0.1s - it feels like pretty much every I2C device should respond within under 1ms but maybe some don't? |
At low level and 100k low speed it works ok: function test() {
digitalWrite(A6,0); // trigger line
I2C1.setup({
scl:B8, sda:B9,
bitrate: 100000
I2C1.writeTo(0x29, 0);
var x = I2C1.readFrom(0x29, 6);
digitalWrite(A6,1);
test(); |
At 400k I see the same working i/o. So problem resides in incorrect I2C init or badly sensor high-level driver. saleae Logic2 traces: i2c_2v25.zip |
next test with LPS25HB pressure sensor: I see regular but not periodic faults every 2-30 seconds, with requests compressed after fault recovery. In normal state sensor requests goes every 1 seconds. Logic2 data: gap_2v25.sal.gz |
2v25 with increased |
LPS25HB driver was omitted, and low-level code was done using sensor datasheet and this sample: Sensor works in continuous measurement mode (1 Hz) without any problems in a long time. |
I've tried to solve this problem on my own but that's something out of my capabilities. Some updates:
So Is there any possibility that errors occur because espruino performs garbage collection and delays reading data? |
I had troubles with js modules for I2C devices since I switched to 2v25 on STM32F405-based board
First I noticed that my VL6180 no longer works correctly. I had failed to find the exact source of problems so I just re-written the module's logic. Maybe my module originally was inconsistent, but it definitly works on later versions.
What's more important, SHT31 module that has been tested for a long time doesn't work at all: it throws Timeout on I2C Write Transmit Mode 2
Noteworthy, both Vl6180 and SHT31 dont work on Hardware I2C an Software I2C setuped on hardware pins
What to you think about this bug? If you propose some tests, I'm ready to perform them and update my report
Thanks in advance!
