Replies: 2 comments 10 replies
Thank you very much thyttan for sharing this here. Very kind of you. Firmware Version 2v25 and it was installed over the Gadgetbridge app loader. With the firmware update app. These are all the apps that are installed of that helps maybe. antonclk (0.11), about (0.15), widlock (0.08), widid (0.03), notify (0.14), widalarm (0.02), boot (0.65), alarm (0.50), widmp (0.09), mylocation (0.11), messageicons (0.08), reply (0.03), widmessages (0.07), calculator (0.08), kbmulti (0.09), noteify (0.03), sched (0.30), widscrlock (0.03), chargerot (0.02), dtlaunch (0.27), messages (0.65), messagegui (0.84), swp2clk (0.05), quicklaunch (0.16), qrcode (0.06), clockbg (0.06), widclkinfo (0.04), widclkbttm (0.06), chance (0.01), widminbt (0.02), grocery (0.05), contourclock (0.33), calendar (0.20), clock_info (0.15), launch (0.22), android (0.42), setting (0.76), lunaclock (0.02) |
Hi, thanks for posting this - so when you do the backup, is that from within Gadgetbridge? Or are you just using the App Loader from the Web Browser? I made some changes recently to use a different method of connecting to the Bangle (via the browser) that allows big files to be uploaded faster and hopefully more reliably - but this looks like it could somehow be related
Do you have it set up to use the 'development app loader'? I've just pushed a change that should fix this. |
There seems to be some problem with the app loader:
https://www.reddit.com/r/Banglejs/comments/1jlntqo/backup_problem/
In addition to this, I've also seen some strangeness on app loader in Gadgetbridge the last day or so. Like it saying the browser not supporting BLE, all the while it definitely works to connect and upload apps.
Edit: I have not tried to reproduce the problem described on reddit for myself.
@gfwilliams
