Message UI has a lot of empty space with the new firmware/app update #7807
Hi, this issue started recently when I updated my bangle js. I can hunt down which version change brought the issue if needed. I think its the new font There are two big areas where we miss a lot of space here. The biggest is the one below the left right icons and the actual message content. The second biggest is the empty area above the blue header saying which app send the message from whom, with the red back arrow. I know we mostly honour this widget line except for clock faces, but imo this message display could also be an exception, since one might want to see a lot of info there. And if we render them, at least show my usual widgets which tells me the time up there. Also I would suggest to maybe not maybe make the heading smaller. Like I know its important so it makes sense to render it big, but that is really big and with the extra padding takes up like a third of the screen... |
Replies: 2 comments 19 replies
What firmware version are you on? Maybe an old one? I believe on recent firmwares you won't have the widget bar at the top, and that will push things up so the text is aligned properly and that gap makes sense |
The recent changes in Message UI brought some more bugs. For instance touching the red/green arrows doesn't work anymore. And regularly, when a new message arrives, it doesn't show the new message but an older one. |
Great - there you go. Uninstall
setuichange- that's what is breaking it. It's already deleted from the app loader, but I guess for those that tested with it, it was left on your device.
