Replies: 3 comments 5 replies
Hi - are you sure this breaks the current tilt implementation? Because we do that using software (not the accelerometer registers) so as long as you're not messing with the accelerometer data rate or range I think it should be ok? |
and one more thing, irrelevant, sorry for that. I have send an email to [email protected], I tried getting two more bangles from the shop, but I get a message saying that there are no shipping options. I can see that the shop is closed till 16th, so maybe that is why I got no reply, but if you could just tell me if Greece is supported or not, I would appreciate it. |
I am leaving here some info, in case one is interested. I was getting some false positives with the double tap feature of the KX022 using my script, and I noticed something I do not like. when double tap is enabled on the accel, it only checks for direction on the first tap, the second one is only checked for time window. This was the cause of my false positives, and it works the same way on the bangle logic too, one can verify by taping on the screen and then on the side, it will register the action, but it should not. in any case, I solved it by disabling the time window for the double tap, I can now have single taps firing very fast, so even a triple tap with direction check is reliable with no false positives. this is what needs changing for this to work: Bangle.accelWr(0x2A, 0x00); // TLT = 0 (no delay) |
Hello @gfwilliams, it is me again 😬
I am finishing the eucWatch port for the BangleJS2, and I stumbled on the twist to wake and face up functions you provide.
None of them works nice for my UI, the twist I do not like, your implementation is fine, but in general I do not like twisting the watch, and it has false positives, It does not check if the hand is raised. I am also used to auto turn off the screen( lock in the bangle case) when the hand is down, I use the "screen off" timer only if the watch is up.
lucky for me , the accelerator is the same as on the DSD6 I have on the toilets, so I made myself a script that resembles the behavior I have on the P8/Magic3 with BMA421 and SC7A20.
It works nice, the screen is on, as long as I can actually see the watch, it doesn't matter if I am sitting or standing or laying upside down on the bed, it will work, and will turn off as soon as I cannot see the screen.
the problem is that I am playing with the accel registers, and I am breaking your twist to wake function. I have it so that I can run bangle apps from eucWatch, I do not change any Bangle settings, so that one can have both UI/environments at will, and this part break the experience.
Can you please test this, and if you like the way it works, maybe consider adding "tilt" to Bangle?
