Web IDE no longer flashing to RAM properly? #7852
I was just developing a new module using |
Replies: 3 comments 9 replies
Have you tried uploading different code? If there's stuff that takes a long time you can always run it in a |
Today I have the same problem : New interpreter error: FIFO_FULL |
But they're caused by the same thing - code taking a long time to run. I'd say just consider writing code to Storage even for testing - it'll solve a lot of issues and is closer to what you get when running from the app loader, so better from that point of view |
Prompt not detectedusually means that the code you uploaded is taking a long time (a few seconds at least) to run as it's uploaded, and so the IDE thinks something is wrong and tries to break out of execution.If there's stuff that takes a long time you can always run it in a
setTimeoutso it occurs after the initial upload is done
