Skip to content
Discussion options
You must be logged in to vote
If you're trying to get your data into Home Assistant I'd strongly recommend using BTHome: https://www.espruino.com/BTHome
It's like someone took EspruinoHub and built it right into Home Assistant - you just have to format the data that the Bangle outputs in the correct way, and there are already some Bangle.js apps which handle this which you could extend with extra data: https://banglejs.com/apps/?q=bthome
Personally, I'd say that's the best bet for sending sleep data for instance. If the Bluetooth range isn't there, I'd spend $5 on an ESP32 board and run esphome on it (https://esphome.io/) - it's a very easy install that can be done from the browser, and it extends the Bluetooth range …
Replies: 2 comments 2 replies
Comment options
1 reply
@HaLo2FrEeEk
Comment options
Comment options
1 reply
@HaLo2FrEeEk
Comment options
Answer selected by HaLo2FrEeEk
Sign up for free to join this conversation on GitHub. Already have an account? Sign in to comment
Labels
None yet
3 participants
