ESP8266 firmware version #858
Posted at 2016-04-21 by Ollie It's not the Pico per se that works or does not with the ESP8266, it's the ESP8266 wifi module that has required slight tweaks to work with the different ESP8266 firmware versions out there. So you might need to try the different modules, but having said that, you can also change the firmware of the ESP8266 either by flashing via the Pico or via your USB-TTL adapter. |
Posted at 2016-04-21 by @gfwilliams I've been using the ESP8266 version 0.40 on some things recently, and it seems to work great -you just need to use the If you do encounter any problems, please let us know rather than downgrading. It seems most modules come pre-installed with 0.40 now, so I really want to make sure it does work faultlessly. |
Posted at 2016-04-21 by Owen Thank for your help guys, I'll stick with the v0.40 firmware and report any issues I run into. |
Posted at 2016-04-20 by Owen
I just bought a new ESP8266-01 wifi module to use on my Pico but before I solder it onto the Pico shim I want to make sure the ESP8266s firmware is Ok. I connected it to a USB-TTL converter and powered up. On COM6 at 115200 I get the following:
AT+GMR
AT+RST
I want to make sure the Pico can work with this firmware version and the memory 8Mbit(512KB+512KB) before soldering it on. Can somebody confirm?
