SSD1306 with SPI1 on Espruino Wifi #919
Posted at 2017-02-13 by @gfwilliams The example does say it's using software SPI as well - so the fact that B5/B6 are swapped doesn't matter as it's not using the underlying hardware. What you've got looks ok - but can you remove Can you also try adding I'm pretty sure I've seen people use that Adafruit display before, so I'm not sure what the issue could be. Please could you also try Software SPI is actually pretty fast, and the WiFi's chip is faster than the Pico's. It could be it's driving the display too quickly! Making it read from a pin as well as writing should slow it down. Perhaps you could try using hardware SPI as well? Just in case, as that will be better at lower speed stuff. |
Posted at 2017-02-12 by CriscoCrusader
@gordon, I'll return to the ESP8266 thread soon-ish, and respond to your last question. Thanks for the help. For now I'm making use of the Espruino Wifi so I can ignore the ESP issue.
I got some of these: https://www.adafruit.com/product/661 SSD1306 displays. I can't get them working using SPI on my Espruino Wifi. I've tried a variety of connection arrangements. It should be simple but it seems every page has different instructions. I was using the table labeled "SPI" at the top of this page, but I now conclude it must be wrong: https://www.espruino.com/SSD1306
Table says:
D0/SCK/SCLK => B5
I assume B5 means SPI1 MOSI (like Pico or Espruino Board). Why would I connect
clock
tomaster out / slave in
?So I'm reading the pins from this table according to the Pico pinout, checking if it makes sense, and connecting to the A pins for the same function on the Espruino Wifi. If they don't make sense, I'm trying to connect like pins to like pins. From what I see online, MOSI goes to MOSI, SCK goes to SCK, etc.
Because all the example snippets I find use software SPI, so do I. Here's my test code that doesn't work:
