Simple game sounds on piezo speaker #971
Posted at 2018-03-27 by @gfwilliams I'd never come across beepbox - that's really cool! Looking at the JSON it looks like you'll want to scan over it and change its form a bit first - basically go over all of Then it'd just be a matter of using Of course you could use Waveform too, but I'd start out simple :) |
Posted at 2018-03-27 by jugglingcats I'll give it a go. I don't know how they do the 'trill' type sound when two notes are to be played together. I assume they alternate between the two notes very fast and setInterval may not be fast enough. Maybe this isn't how it's done but it doesn't sound like a proper chord. My music knowledge very limited! |
Posted at 2018-03-27 by @gfwilliams In hardware there's a good hack for two notes at the same time - which is just to attach the piezo to two signal pins and use PWM on both (= two channels). However if you use |
Posted at 2018-03-27 by jugglingcats That's a good tip to use two output pins -- will try it! |
Posted at 2018-03-26 by jugglingcats
I have a little piezo speaker hooked up to a Pico. I'd like to generate some simple 8-bit game-type sounds for it.
What I'd really like to be able to do is export sounds created on http://www.beepbox.co (they have JSON export) and add them to Espruino projects.
The sound would need to play in the background so I think this would need to be implemented as some kind of task, but beyond that am not sure where to start.
Any ideas appreciated!
