Can't write to a custom Characteristic through EspruinoHub (stuck at "Getting Service") #975
Posted at 2018-04-23 by @gfwilliams Hi,
Occasionally - when you specify a second argument to setServices for the services you want to advertise (but you're not doing that here so I don't think it's an issue).
That all looks good to me. I'd maybe try using a newer firmware on Puck.js just in case? I just tried your code here and while |
Posted at 2018-05-05 by Ron Thanks for the tips. Finally figured it out – turning off the WiFi module of the Raspberry Pi (putting Now it works nicely most of the time. It just occasionally times out with: Is this expected? Do you see the same behaviour? Any ideas how to achieve more reliability, apart from maintaining a persistent connection? |
Posted at 2018-05-07 by @gfwilliams Interesting about the WiFi - I haven't had to explicitly disable it on my Pis however I believe I'm running the Lite Raspbian which doesn't have the desktop and so I imagine won't be using WiFi to scan for access points of anything. If you actually use WiFi for connections you'll have huge issues though since it's trying to use the same aerial. Occasionally it will fail, it's pretty much guarantees - I guess potentially that code could be improved to retry after a timeout, or you could make the service readable and could perform a read after the write in order to check that everything was ok? |
Posted at 2018-04-22 by Ron
I can't find a way to write to a custom service/characteristic exposed on the Puck from Node-RED through EspruinoHub.
However:
/ble/write/puck/nus/nus_txthrough EspruinoHub worksThe problem only appears when writing to the custom characteristic through EspruinoHub.
It seems it's not related to Node-RED since the same problem appears also when the MQTT message is published using
mosquitto_pub.Following the guidance in https://www.espruino.com/Puck.js+Node-RED ...:
...and the guidance in http://www.espruino.com/Reference#l_NRF_setServices, this is the code I have on the Puck (first part unrelated (?), but adding for completeness):
And publishing to
/ble/write/puck/0000aaaa00001000800000805f9b34fb/0000aaa000001000800000805f9b34fbyields:Even extending the
CONNECTION_TIMEOUTto 30s and the "getting services" timeout to 15s didn't help.Any ideas?
Is there some interplay between
setAdvertisingandsetServices?Am I using the wrong format for specifying service/characteristic ID? (Tried short
aaaa, long0000aaaa00001000800000805f9b34fb, hex0xaaaa, capitalized, non-capitalized, etc.).Environment:
