[SOLVED] 7 Segment driver MAX7219 : handling the dot on floating numbers #984
Replies: 9 comments
Posted at 2018-06-13 by @gfwilliams Hi - yes, it could definitely be tweaked. I guess you'd want Can you try adding this code after you have initialised the MAX7219 and trying again? |
Posted at 2018-06-13 by @yerpj @gordon, I had to wait less than 16 minutes to read the solution from you... You are by far the most brilliant support ever! :) I don't have the module on hand right now but I will try your code tomorrow morning. |
Posted at 2018-06-13 by @gfwilliams No problem! Let me know if it works for you and I'll update the module's code with the new function :) |
Posted at 2018-06-14 by @yerpj it works like a charm! tested with Everything is working as expected. Thank you very much @gordon !! Regarding the above testing, I think the module can be upgraded :) |
Posted at 2018-06-14 by @yerpj Whoops, I spoke a little quickly. I did not test a specific case when there is not sufficient digits to print the value: |
Posted at 2018-06-14 by @gfwilliams I just tested that, and it's to be expected. Because of rounding, If you want full control over it, convert it to a string manually yourself and pass the string in - eg: I'll update the library with the new code :) |
I didn't even thought this far. This seems to make sense. Thanks! |
Posted at 2018-06-14 by @gfwilliams It's all updated now, so using |
Thank you very much, it works well! |
Hi there,
I wonder if anyone has tried to handle the dot (".") LED for displaying floating numbers, using this piece of HW? https://www.espruino.com/MAX7219
In the MAX7219 datasheet, page 7 ( https://www.espruino.com/datasheets/MAX7219.pdf ) , it says
Which seems to allow handling the dot (DP).
Do you guys think the MAX7219 module could be upgraded in order to support displaying floating numbers?
